Online PCBs with parts, free PCB software.
Pad2Pad
Hi All,
You can now get custom PCBs online - with components! At the new
pad2pad.com you can easily design, price, and order custom printed
circuit boards with components - at low cost. Pad2pad.com includes
free PCB layout
software. Please visit www.pad2pad.com for details.
Regards,
James Smith
www.pad2pad.com
Ben Bradley
In a commercial crosspost to these groups:
sci.electronics.design,
sci.electronics.cad,
sci.electronics.basics,
sci.electronics.misc,
comp.robotics.misc,
Hi All,
free PCB layout
Oh how interesting, this looks like a direct competitor to
http://www.expresspcb.com which has offered a similar service (but
without any boardstuffing) for several years now. Perhaps the extra
competition will bring down the cost of both of these services (but I
hope not the quality, expresspcb's boards have always been good for
me).
David Knaack
[snip]
[snip]
Has anyone given Pad2Pad a try yet? I've installed the software and
checked it out and it seems pretty decent for the kind of simple hobby
work I do. Much more polished than Eagle, which desperately needs some
UI polish.
The prices are pretty reasonable, much better than most of the domestic
board houses, but still not as good as Olimex. But being closer is
enough to get me to give them a try.
Any experiances yet?
DK
W
Walter Harley
UI polish.
Eagle is certainly lacking in that department. However, Pad2Pad didn't look
like it had any facility for checking against a netlist? This quickly
becomes a limiting factor, even with a dozen or so components. One really
wants to be able to input a schematic and see whether the nets on the PCB
match it.
Alan Kilian
I've used Eagle and Olimex for three boards so far, and other members of our group
(tcrobots.org) have used Eagle for more projects.
I can't see any of us using a system that doesn;t start with schematic entry
and electrical design rules checking.
I haven't really had problems with Eagle's user interface either, so I can't
comment on it.
I did a project using 8 PICs and 2 motor drivers to implement a 4-channel
PID motor control board, and got two PCBs for $28 from Olimex.
http://bobodyne.com/web-docs/robots/Trippy/Board/index.html
Eagle and Olimex worked perfectly.
(Also, I'm a Linux guy, so Windows software is unlikely to cut it for me)
Pad2Pad
However, Pad2Pad didn't look like it had any facility for checking against a
netlist? This quickly becomes a limiting factor, even with a dozen or so
components. One really wants to be able to input a schematic and see whether > the nets on the PCB match it.
Dear David,
Pad2Pad does support checking of your design against netlist (Board |
Design Rule Check), but in current version you have to input netlist
manually (either by using Logical Connections tool or in Nets | Edit
Nets dialog). Import of netlists will be introduced in posterior
versions.
Sincerely,
Pad2Pad customer support.
Patrick Timlin
UI polish.
Looks ok, but like ExpressPCB it looks like it is a program that is
designed to only be used with that companies manafucturing facilities.
In other words, there is no standard Gerber file generation so that
you can take your design to other board houses. You are locked into
using Pad2Pad for your board manufacturing and would have to generate
the artwork a second time on another package if you wanted to go
somewhere else.
At least that is what it looks like to me with the few minutes I spent
looking at it. If I am mistaken, I am sure someone will quickly
correct me.
P.
Pad2Pad
Dear Alan and Walter,
Pad2Pad does support design rule check based on netlist (choose Board
| Design Rule Check). Currently netlists can be created graphically by
using the Logical Connection tool, or specified in Nets | Edit Nets
dialog, or created automatically from traces. In one of the nearest
updates Pad2Pad will also support import of netlists from other PCB
design applications.
Sincerely,
www.pad2pad.com
W
Walter Harley
Thanks. Another thing you could do to entice potential customers would be
to publish at least some sample prices on your web site. I'm disinclined to
go to the trouble of downloading the software, learning it, and creating a
sample board, just in order to find out whether your pricing structure is in
line with my needs.
Don Carroll
no Linux Version , then no good to me , I refuse to run MSWindows software
get a Linux Version then we can talk , what is the max board can you do
with your software
G
Guy Macon
Pad2Pad said:
Import of netlists will be introduced in posterior versions.
You *really* want to start saying "future versions" instead of
"posterior versions" unless you want to get behind in your work.
David Knaack
I'm also using Eagle and Olimex for my projects, which are always small.
Small enough that I can get a way with working without any kind of
schematic capture or design rule checking, although I prefer not to have
to do that, it is rather tedious.
comment on it.
Its not really problems so much as just being a bit weird and opaque.
I'm sure its like most CAD programs where those of you who spend hours
working with it quicly become accustomed to it, but as rarely as I use
it it always feels awkward and old.
As a professional software designer myself, I'm probably just overly
critical of interface design.
Olimex rocks, I just wish they weren't so darn far away. The first time
I got a board from them I had to pay UPS a $75 brokerage fee, 3x the
board cost!
DK
Dave Baker
If it could import ExpressPCB boards then I'd start using it tomorrow. I
dread having to convert my circuit layout across again. I think I will have
to anyway though...
I'm a bit confused with the component list. For example, I have to place an
LM2676S-ADJ voltage regulator on the board, but trying to find a suitable pad
layout for it has turned into a major task in itself.
Dave
The email address used for sending these postings is not valid.
All replies to the group please.
Robert Baer
to anyway though...
Dave
Get the data sheet; most have pad layouts on or near the last page.
Dave Baker
Oh, I have that already - have the components & already have an ExpressPCB
board made up & about 20 populated boards done & sold already. I'm looking
for the proper pad layout on the list of available "components" in the
Pad2Pad application. It's a strange component with 7 SMT legs at the bottom &
a large pad at the back for the earth on the voltage regulator.
The strange thing is that the Pad2Pad application looks almost exactly the
same as the ExpressPCB application - I had to have a look to make sure it
wasn't the same company when I first started up Pad2Pad. :)
Dave
D. Jay Newman
Will your company accept Eagle files?
I have no intention of learning a vender-specific PCB package
merely to try it out.
Stephan Rose
Not only that but....what if that vendor ceases to exist one
day....now you're stuck with a PCB package that's essentially useless
if it can't import and most importantly..export non-vendor specific
formats...
Stephan
