No - just thought that for an analogue meter a device that made
(milli)volts all by itself would be likely to keep things simple. What's
better?
A thermistor or semiconductor sensor would be simpler to work with.
National, for example, has some. Thermistors are nonlinear so a bit
harder to work with, but cheaper and more accurate in quantity (not
necessarily more stable). A coil of copper wire can be a cheap
temperature sensor. A loose coil of thin Pt wire is one of the most
stable temperature sensors made. If you are not so fussy, a thin film
of the stuff will do. HVAC folks use thin films of base metal stuff
like nickel.
Here's a semiconductor sensor that costs around $1 in small
quantities:
http://cache.national.com/ds/LM/LM94022.pdf
You need a sensor such as the above in order to be able to use a
thermocouple anyway! (for cold junction compensation).
Best regards,
Spehro Pefhany
