DIY Kit Current Limiting (0 - 30V, 2mA - 3A) Continuously Adjustable DC Regulated Power Supply
http://www.gearbest.com/development...62rEZG06prA1yyxc8ZuBBK7EaQUItzM0EgaAmMp8P8HAQ
This online kit looked good at only $15 - it looks pretty good and is way more than I need -.
But when I started looking at all the extra hardware, transformer, panel meter, case, heatsinks, etc, it soon blew out to over $50 - way too much for what I need -.
But after I opened up a blown ATX PS - caps -, I noticed all the hardware I need to finish the kit was inside for free. The gutted ATX case has a 12V fan, 240V connections, 240V switch, case, heat-sinks, and what I think is a filter - cap and inductor - soldered to the inside 240V socket, so it's practically ready to go.
The kit needs a 29V 3A 240V transformer, but I only need something like 12V 1A, and looking inside the ATX PS there is a large-ish EI-40c transformer.
I can't find an accurate datasheet, so I don't know if it will be suitable.
Maybe this
http://www.kondzio.info/images/artykuly/2015/transformator-impulsowy/EI-33-datasheet.pdf
http://chipsen.en.made-in-china.com...a-EI40-Current-transformer-specification.html
Here are some pics
https://www.mediafire.com/convkey/c141/4uva5mjt899iyto6g.jpg https://www.mediafire.com/convkey/edff/z66lnkp4g9f05jd6g.jpg
https://www.mediafire.com/convkey/5cfc/snsaot1xhjknz3b6g.jpg
I removed the EI-40c, and it has 3 legs on the input with the centre one cut - I presume it's for 110V -, and the output has 6 pins and a large common. Do you think I can use this transformer?
Any advice would be appreciated. Thanks
Maybe this
Here are some pics
