Hi I am having problems with an Onkyo TX-NR5007 going into protect mode. I have experience fixing a few other receivers but I am struggling to narrow down the problematic areas to check for this one. The service manual can be found here:
https://elektrotanya.com/onkyo_tx-nr5007bs.pdf/download.html
Things checked/tested so far:
1. All output transistors seems ok.
2. Fuses are all intact.
3. All 3 Bridge diodes on PC boards seem ok.
Testing observations:
1. If i remove all the vertical amplifier pc boards from BAAMP-0191, does not trigger protect mode.
2. By connecting JL6041B wires individually, the signal triggering protect mode is coming from VPRO line. IPRO does not trigger.
Any help to filter down which areas to check or possible causes is greatly appreciated.
