Phil Allison
**Hi,
an Alesis power amp ( Matica 500) arrived the other day, with a fixed AC
lead ending in a UK 13A plug.
I have a simple adaptor for such occasions - so used it until finally
fitting an Aussie 3 pin plug as requested by the owner.
The UK plug had a 10A BS1362 fuse inside, all fine and dandy.
Then I wondered if the same amp had used an IEC inlet, that creates a
problem for UK owners in that they must use a correctly fused IEC lead with
it.
Does this create many false alarms when an IEC lead with a low value fuse is
used by mistake ?
.... Phil
it.
used by mistake ?
.... Phil
