Old transistors data sheets - Where?
I
Independence
I came across a large box of unused assorted transistors in a box of junk
from a TV and video repair business that had closed down and left them all
at our rubbish tip trash and treasure exchange. Most are new although some
are rather superficially corroded on the metal cases.
I have searched at http://www.alldatasheet.com/ to identify the components
and have had some success, but many of them do not show an exact match.
Although I am a telecom engineer, and know a bit about them, I haven't had
much to do with such components for quite a while.
I want to make use of some in a couple of projects, but lacking the data
sheets I'm not sure what is what, although many are obviously power
transistors of some kind.
Is there a good source of data sheets for older components other than
Sometimes the above website comes up with similar numbered components but
they are obviously different components, just from the physical appearence.
Here are just a few I can't exactly match. Figures after the comma are
secondary numbers listed on the components under the main mumbers.
Sanyo C1050E, 5k
Sanyo B407 tv, 4g
Sanyo SD68C, 5A
Sanyo D416, 6B
SonKen 25D201
D621M, 8E
NEC 2SD388, R57
Sanyo 2SD68C, 4J
Sanyo C1050D, 5G
Sanyo C1050E, 5H
Sanyo C1050E, 5K
Sanyo C1050D, 5K
BU326A, T8947
NEC 2SD388, K3YA
Matsushita 2SD198
These are just som examples which may show the age of the components, there
are literally hundreds of others, transistors big and small.
Can anyone suggest where I might get datersheets on these "antique"
components please?
Alan Rutlidge
appearence.
Sanyo C1050E, 5k
Sanyo B407 tv, 4g
Sanyo SD68C, 5A
Sanyo D416, 6B
SonKen 25D201
D621M, 8E
NEC 2SD388, R57
Sanyo 2SD68C, 4J
Sanyo C1050D, 5G
Sanyo C1050E, 5H
Sanyo C1050E, 5K
Sanyo C1050D, 5K
BU326A, T8947
NEC 2SD388, K3YA
Matsushita 2SD198
there are literally hundreds of others, transistors big and small.
components please?
I use a publication called VRT (ISBN 981-214-126-X) which lists the main
characteristics as well as equivalents.
Altronics stock it.
http://www.altronics.com.au/index.asp?area=item&id=B1271
Cheers,
Alan
Ross Herbert
On Thu, 20 Mar 2008 16:25:52 +1000, "Independence"
:I came across a large box of unused assorted transistors in a box of junk
:from a TV and video repair business that had closed down and left them all
:at our rubbish tip trash and treasure exchange. Most are new although some
:are rather superficially corroded on the metal cases.
:I have searched at http://www.alldatasheet.com/ to identify the components
:and have had some success, but many of them do not show an exact match.
:Although I am a telecom engineer, and know a bit about them, I haven't had
:much to do with such components for quite a while.
:I want to make use of some in a couple of projects, but lacking the data
:sheets I'm not sure what is what, although many are obviously power
:transistors of some kind.
:Is there a good source of data sheets for older components other than
:http://www.alldatasheet.com/
:Sometimes the above website comes up with similar numbered components but
:they are obviously different components, just from the physical appearence.
:Here are just a few I can't exactly match. Figures after the comma are
:secondary numbers listed on the components under the main mumbers.
:Sanyo C1050E, 5k
:Sanyo B407 tv, 4g
:Sanyo SD68C, 5A
:Sanyo D416, 6B
:SonKen 25D201
: D621M, 8E
:NEC 2SD388, R57
:Sanyo 2SD68C, 4J
:Sanyo C1050D, 5G
:Sanyo C1050E, 5H
:Sanyo C1050E, 5K
:Sanyo C1050D, 5K
: BU326A, T8947
:NEC 2SD388, K3YA
:Matsushita 2SD198
:These are just som examples which may show the age of the components, there
:are literally hundreds of others, transistors big and small.
:Can anyone suggest where I might get datersheets on these "antique"
:components please?
You could try datasheetarchive http://www.datasheetarchive.com/
I find that they usually have somesort of data on even nondescript devices and
they are adding new stuff all the time.
L
Lance Shiells
Just tried http://www.alldatasheet.com/ with the Sanyo C1050E, 5k which is
really a 2SC1050E with no probs , note from memory most of those tranistors
had the 2S dropped so C1050E is 2SC 1050E ...same goes for most of the
other tranistors.
Cheers
Lance
