Could some electronics guru please help ?
I have an old (about 7 - 8 years) +/-15
Volt 2 A power supply that so far has
been very reliable. It is a standard
linear design, with the transformer is
rated at +/- 20 Volts 2A max. The output
voltage is adjustable via pots at the
+/- terminals. Recently, I have been using
it to run two CPU style fans that cools a
experimental server machine.
I have noticed that recently the fans
start at full speed, but then become
slow. Each fan is rated at 12 Volt, 0.17A
(170 mA). So I checked with my Fluke
the voltage outputs at various point.
The transformer AC output is a steady +/-
20 Volt, but the DC output of the rectifier
+/- 30 Volt!. Also, a voltage regulator
that comes after the rectifier is becoming
extremely hot(even with a thick heat sink)
and when the fans slow down, the output
voltage drops to 8.4 Volts, as opposed to
the preset value of 13.0 Volts. Any ideas
as to what the problem might be ? Obviously
that current being drawn by the fans is
increasing, leading to the droop.
