Hello to you all, my first question.
What i am trying to find an answer to is if i convert an old pc power supply can i use an alternative apart from the suggested 10 watt 10R or 5R load resistor, is it possible to trick the supply into believing its got a load on the output, i know the above resistor only uses an amp or so if 4.7 ohms on the 5 volts rail, i have heard a wire back to one of the low voltage IC's from the 5 volt rail could be a way but not sure beyond that.
Just wandering if any other member has tried an alternative, my experience is average i would say, so am no expert, and ideas appreciated.
