Old oven timer makes a noise when oven is off
This is an old electric powered oven. Ive never touched the timer but
it is giving off a noise like low boiling water. The transformer is hot
to the touch. Disconnected power to oven and noise stopped. I assume
that when the timer and oven are off that the transformer should not be
hot? I assume something has shorted?
James Sweet
The transformer will likely be hot all the time as it's always switched on.
Does it have a mechanical timer or clock?
Sam Goldwasser
the following 2 links are pics of the front and back of timer
http://img403.imageshack.us/img403/4403/00006075nf.jpg
http://img403.imageshack.us/img403/5584/00005993ep.jpg
it has a minute timer which appears to be mechanical and stop and start
dial.
The motor is making noise. Eventually it will stop but there's nothing
dangerous. The motor or just the rotor/gear module - the silver part on
the right hand side of
- can be lubed or replaced (if you can find one).
--- sam | Sci.Electronics.Repair FAQ: http://www.repairfaq.org/
Repair | Main Table of Contents: http://www.repairfaq.org/REPAIR/
+Lasers | Sam's Laser FAQ: http://www.repairfaq.org/sam/lasersam.htm
| Mirror Sites: http://www.repairfaq.org/REPAIR/F_mirror.html
Important: Anything sent to the email address in the message header above is
ignored unless my full name AND either lasers or electronics is included in the
subject line. Or, you can contact me via the Feedback Form in the FAQs.
