Tim Williams
This is an Elgenco 331A gaussian noise generator. I know very little about
it, though I did see an ad in an old journal proclaiming it's good to four
sigmas. It seems to be roughly "audio frequency", by which I mean, the
circuits are audio quality, no particular attention paid to high or low
frequency bandwidth (AC coupled, no peaking coils). I would guess 10Hz to
200kHz or so.
Front view. Some old rackmount thing:
http://myweb.msoe.edu/williamstm/Images/Gaussian_Noise1.jpg
So I'm guessing Beloit got it from NASA surplus or something. I found this
thing on the curb one day outside of a house near the college, which I'm
assuming is the residence of someone interested in Beloit physics...
Other side of the faceplate:
http://myweb.msoe.edu/williamstm/Images/Gaussian_Noise2.jpg
Behind the faceplate, the noise generator and amplifiers:
http://myweb.msoe.edu/williamstm/Images/Gaussian_Noise3.jpg
On the far right, two 6D4 gas thyratron triodes are set in magnetic fields,
generating noise per the datasheet. They look to be connected like any old
gas tube, with coupling capacitors going to the rest of the circuit. I'm
going to guess they use two and mix them somewhere (I haven't traced the
circuit yet), to make it extra randomized or something.
Signal leaves through the coax in the top-right corner, which goes to the
output stage on the left (coupled through that big fat 1.0uF). I think it's
a 12AU6 cathode follower.
On the far left, two PCBs hold some germanium transistors (typical date
codes are 1963), the TO-39's are 2N398As, while the TO-1's are something
rather fancy (I forget the number, but they're epitaxial mesa germaniums
with almost 100MHz fT). I don't really know what to make of it, but it must
be in the signal path, why else use such fast transistors.
PCB closeups:
http://myweb.msoe.edu/williamstm/Images/Gaussian_Noise4.jpg
Gotta love that clear glass body RN60B!
The power supply hangs in the back of the rackmount chassis (which must be
annoying for the moment arm...)
http://myweb.msoe.edu/williamstm/Images/Gaussian_Noise5.jpg
Two potted transformers supply everything, I think one is for heaters, the
other for HV, and the thermal relay (bottom right) delays HV by a minute or
whatever. Rectifiers are all silicon (I guess).
A 6BX7 and associated tubes (12AX7, and the other one may be another 12AX7)
regulate high voltage. The two PCBs and heatsink appear to regulate 12.6V
for heaters. The TO-3's are all 30V, 1-5A germaniums. The two pots say
they're for + and - 156V, I guess one or both go to the tube regulator part.
Either that or some of the TO-39's are HV germaniums, I haven't checked.
Rear view:
http://myweb.msoe.edu/williamstm/Images/Gaussian_Noise6.jpg
Filament supply seems to be the bottom transformer, feeding a press-mounted
FWB and computer-grade cap.
Tim
200kHz or so.
PCB closeups:
Rear view:
Tim
