Old Motorola 3.6V chips - RTL? DTL? Anybody remember them?
Rich Grise
I was just sitting here whiling away a Friday afternoon, with the weather
more amenable to having a picnic, and happened to think of some of the
first integrated circuits (ICs) I ever heard of - they were from Motorola,
and ran off 3.6Vdc Vcc, and they were either RTL or DTL, or maybe there
isn't that much difference in those technologies.
Oh, OK. I'm reminiscing. Sigh.
Say, Jim Thompson - didn't you used to work at Motorola? I'm not going to
say I think you worked there at the time, even though you are more than
a year older than I am ;-), but I was just sort of wondering if you or
anyone else remember those chips. Their part number was something like
MC733 or MC312 or something like that - two letters to indicate "Motorola"
and three digits.
Anybody remember them, or have any stories about using them?
Thanks!
Rich
John Larkin
and three digits.
Thanks!
Rich
The first digital ICs I used were Moto RTLs, packaged in a round black
8-pin glob-top with wire leads, like the old Fairchild transistors.
Noisy, nasty, unreliable power hogs, as I recall. Noise immunity and
fanout were both the pits.
MC7xx maybe.
John
Jim Thompson
MC7xx maybe.
John
I was at Motorola SPD from 1962-1970.
Besides all the analog stuff I did I was involved with ECL, RTL, DTL,
TTL & PECL, but I really only remember the TTL and ECL/PECL numbers.
RTL sucks for noise immunity EXCEPT when everything stays on-chip.
I've done a number of analog chips with simple-minded RTL logic
sections, but my preference is BiCMOS.
...Jim Thompson
W
Winfield Hill
John Larkin wrote...
MC7xx maybe.
Didn't Fairchild make those, that's what I used, IIRC.
Tam/WB2TT
Pretty sure the 3.6V parts were RTL. Max fanout was only 2 or 3 loads. I
shouldn't have thrown out the old Moto manual.
Tam
John Larkin
I used the Moto RTL stuff for a while, until DTL came out. Flirted
with SUHL and Utilogic a bit, too, until TI/TTL finally won.
I seem to recall (mists of time and all that) that the globtops were
Motos, but they may well have been Fairchild. I posted a couple of
pics to abse; this catalog, 1966, shows them in round metal cans, 8 or
10 pins.
Wow, just tripped across the datasheet for the MR1290, a 1000 amp
silicon diode. It's water cooled!
John
Michael A. Terrell
10 pins.
John
The Fairchild RTL I used was in a flatpak configuration. I also have
(or had) some RTL with NASA markings for the 914 and 923 chips.
prove it.
Member of DAV #85.
Michael A. Terrell
Central Florida
Joseph2k
If Fairchild made them the part numbers would be uL7XX not MC7XX.
Barry Lennox
and three digits.
Yes, I remember them well, grey ceramic/black epoxy blob things? built
a scope timebase using one. Rushes to old semi junkbox,-- Thought I
spotted one, but no it's a Fairchild SE6001. Right in between a CK722
and several OC170s.
Barry Lennox
Ancient_Hacker
They were probably RTL. Really Terrrible Logic. Although at the time
they just took your breath away. Two NAND gates in one little TO-5
size package!! WowWee!! Even more impressive was the 923 J-K flip
flop.
The outputs had a 400 ohm pull up IIRC, and the inputs had a 600 ohm
input resistor. So you couldnt hook up too many inputs to an output
before the logic swing went way down and the marginal noise immunity
went to zero. And the flip-flop used a retarded charge-injection
transfer scheme, so the clock had to have fast transition times, or the
flip-flop wouldnt flip. Pretty sorry logic, but at the time there
wasnt anything better at a reasonable price. DTL was available, but
IIRC only at military part prices. Eventually Fairchild saw the light
and started making DTL, then the price went down exponentially and the
stuff caught on.
L
legg
and three digits.
Thanks!
Rich
MC800-900 series were RTL in metal cans or ceramic flat-packs.
MC700-800 series were RTL in 14pin DIP (TO-116)
Tesed at 3V, rated for 12VCC surge, with +/- 4V input tolerance.
The low fanout meant a lot of 'gate expanders' on offer.
RL
