I am a bad choice for electronics assistant. I can put things together well, and can take them apart equally as well. I have a basic understanding of electronics, circuits and how it all works. I cannot program my own boards yet, but I know some BASIC, and I am internet literate. I have a handful of electronic parts i have scavanged from boards, and I am in way too deep for my feeble old mind to realize. Electronics is a relief for me. i like watching-making things electronic work. I got a really great buy on an old 83 motorcycle that has a hitachi 2 connector (14 pin) TCI(transistor controlled ignitor) on it that I fear is failing. Everything else checks out,,,that means the TCI is not working right. Anyway, I want to check it out, I have a cheap hantek 1008c scope, and a bosch vom. I know how to use them. But...I don't know what I am looking for! and I am very embarassed! So assume for a sec that you have this black box that has 2 male ports looking at you... the one on the left has 6 contacts( they connect the 4 center tapped field coil sensors-2 points on each coil, totalling 2 coils and 4 points- picking up the rotation from the flywheel to the TCI and a ground) And the one on the right has 8 contacts( they send the firing order individually to the ignition coils for sparking the resistors at the right point in the timing) The board is non-removable...not that I couldn't remove it... but the contacts are waterproofed into the plastic case and I would have to clean the solder off the board with a solder sucker possibly damaging the board. KWUESTION? In your opinion,
1. is it important to access the board so that you can use the bikes onboard systems to test it? like would you cut the plastic case open on one side to access the board.... OR
2. should I bite the bullet, dig out the solder sucker, disconnect the board and build an elecctronic testing stations from what I haev on hand(I would hate to ruin it or discharge the charged caps it may have on it... )
It is a Hitachi 14-17 26h Venture Royale TCI, and I can't find any specs, schems or repair kits for it. The Venture Royale was a combined work of Yamaha, Mitsubishi and Hitachi. It has Asahi malable steel wheels if it is of any brain food to you........
