Bob said:
Hello. Does anyone know were I can find the old BYTE magazine GPIB to
centronics printer interface article. (circa 1979 +/- 4 years)
Regards, Bob S.
The GPIB state machine is exceedingly complex. If you need all of it,
go buy the chip. The good news is that many applications need almost
NONE of it implemented. If all you want is to be the controller in
charge, you just need to address the device and handshake the data.
If that will do, email me and I'll send you some basic code written for
a PIC processor that implements RS-232 to GPIB. Should be easily
adaptable to centronics.
If you want to use the printer port on a PC I can email you this:
This archive contains files that describe how to convert an inexpensive
parallel printer adapter on a PC to interface with GPIB (or
HPIB/IEEE-488)equipment.
Don't know where I got it, so can't give you a link.
If you don't need to use the national instruments code, you can buy
older non-compatible gpib cards for cheap.
mike
Return address is VALID.
500MHz Tek DSOscilloscope TDS540 $2200
Wanted, 12.1" LCD for Gateway Solo 5300. Samsung LT121SU-121
Bunch of stuff For Sale and Wanted at the link below.
http://www.geocities.com/SiliconValley/Monitor/4710/
