Skybuck Flying
Hello,
While I was inspecting the cables I noticed some speakerset cables where
lieing on top of the WHITE television cable that carries the television
signal.
I decided to pull the white cable while the television was ON.
Then I moved the black soundspeaker cables under the white cable.
Then I re-plugged in the WHITE CABLE...
BUT JUST BEFORE I PLUGGED IN I NOTICED THE TELEVISION SIGNAL WAS RESTORED,
AT LEAST THE AUDIO SIGNAL ?!?!?!
I was like WHAT THE **** ?
I could have sworn it wasn't plugged in yet, or maybe just reaaally lighty.
So I decided to unplug it again and then simply hold the cable in the air ?!
Like 1 centimeter before the "hole".
AND IT FUCKING WORKS !
The television signal simply JUMPS ACROSS 1 CENTIMETER OF AIR !
Then I looked over the television and the television vision/visual was gray
like with weak visual signal... but the audio signal was crystal clear ?!
AMAZING !!!!
ALMOST LOOKS LIKE MAGIC ?!
HOLYSHIT.
Could this be the source of the interference ? Just pure speculation.. since
when the first booms occured... the television was off ?!
Bye,
Skybuck.
signal.
AMAZING !!!!
HOLYSHIT.
Bye,
Skybuck.
