Phil Allison
** Hi,
following recent debate here and since midday Sunday, I set up a simple rig
to monitor the incoming AC supply for "ripple" tones superimposed by the
local energy supplier.
The rig consists of a 12VAC, 1A plug pack with a series tuned LC filter (
10uF and 2.5mH ) and a 6 inch speaker. When the tones arrive, you can hear
them easily and also see them on a CRO - the first discovery is that the
tones here in the inner west of Sydney are at 744 Hz and not 1050Hz, as
often quoted.
The tones first arrived at 4:55 & 4:59pm on Sunday - then at 5:15, 5:16 &
5:17pm - then 9:30, 9;31 & 9:32pm - then
10:02 & 10:03pm and finally at 10:25 & 10:28pm. Long (ie 25 second) and
short bursts of tone were involved.
Very likely, 4:55pm on a Sunday corresponds with the beginning of the
evening load peak, 9:30pm with the tapering off of that peak and the later
times with ever lowering demand.
The afternoon pattern is repeating itself, almost exactly, as I write.
The level of the superimposed tone is about 12V rms. It is not a pure sine
wave, but has several components at 100Hz intervals above and below 744Hz -
as seen using the FFT function on a Rigol scope.
Could these be AM modulation products, produced by non-linearity in the
distribution system ?
This link says that such tones are found in NSW and south eastern QLD plus
NZ.
http://www.spinifexfans.com.au/resources/noise-ripple-control/
..... Phil
often quoted.
NZ.
..... Phil
