Brad
I have an RCA TV/VCR/DVD combo, model 27F500TDV (mfg Nov 2003) in my
shop. When you try to play a DVD, a message, "Incorrect Disk" occurs. I
also tried a home made DVD which has home videos recorded on the disk (same
message). Note: I tried 3 other DVDs (same message). However, audio CDs will
play just fine. Note: I cleaned the lens, which already looked very clean.
Inside, everything is very clean.
If I replaced the DVD player assembly, will this fix the problem?
Thanks in advance, Brad
Before you type your password, credit card number, etc.,
be sure there is no active key logger (spyware) in your PC.
