Sir mityeltu . . . . .
I can’t see those being other than just one watt encased Zener diodes, possibly at some custom 7 volt variant from the normal assigned bracketing values of 6.8-----7.5 VDC Zener thresholds..
How about doing a non destructive testing, using a 24VDC supply and a series current limiting resistor of 1k to its cathode.
That should tickle the unit enough to see what its Zener threshold is being .
If that gives no reading, suspicion that you just might have yourself a special unit on up in the ~70 V region, and use a higher 100VDC and a 10 K resistor to do the same test.
That house number is being a dead end lead, otherwise, but Motorola did use that diode prefix in olden tymes on some of their diodes...
73’s de Edd
