After looking over a lot of cool projects based on the ATMEL family of
microcontroller, I just bought a bunch of ATMGAG8-16PI's. I bought
these because I was under the impression these where very easy to play
with:
* On chip RC oscillator, no need for a crystal for simple stuff
* Lots of I/O pins with decent source and sink capacity - can light up
LED's directly
*A/D converter (might be fun to play with)
*No hardware programmer required - a few resistors hooked up to a PC's
printer port.
*Lots of free tools - assemblers, compilers, libraries etc.
Ok, so I have a bunch of the chips and I have downloaded and built up
the Linux AVR tools, the gcc cross compiler etc. I have also
downloaded the AVR Studio from ATMEL.
Now, here is the thing, it seems that the Linux AVR tools will support
the really simple "few resistor" type of programmer, whatever that is
called. I am not sure if the AVR Studio or any windows 2000/XP
software will support the same few resistor type programmer. I have
been looking around and I have found:
* A few of the few simple resistors and printer port based
programmers. The gotcha is just about all of them use different pins
on the printer port! They all use the same pins on the chip. Is
there not a standard for this? How do you know what will work with
what?
* A few that look like the above but that terminate in a dedicated
programming connection on the board with the micro. (JTAG?)
* A few of them that hang off the printer port and use different
amounts of old TTL logic between the printer port and the mico.
* A few of the above that go into the dedicated connection on the
Are these guys cross compatible with the same programming software?
Being a big fan of making my own life easy, why would you add more
gunk between the two pieces?
* Then there is the breed that hangs off the serial port on a PC.
* Then there are the little dedicated "programmer" boards with the ZIF
sockets and what seems to be a lot more silicon in the programmer
itself.
So, can some kind soul tell me what the really cheep and easy
"resistors and the printer port" type programmer is called and point
me at some windows software that supports it (my linux box is a
desktop in another room, and I would like to be able to program these
from my notebook in the shop. The notebook runs XP and is unlikely to
change)
Also, if you can elaborate on what makes the different types of these
programmers "better" on "worse" then the other types. If I catch the
bug I suspect I will upgrade if the other types do something neat or
that can not be done with the Q&D ones.
Thanks in advance!
Matthew
*** Free account sponsored by SecureIX.com ***
*** Encrypt your Internet usage with a free VPN account from http://www.SecureIX.com ***
with:
LED's directly
printer port.
what?
itself.
change)
Thanks in advance!
Matthew
