I want to convert the output from a NTSC camera to RCA for input to a micro controller project.
Is there a schematic available?
Thanks!
Thanks!
Hi and welcome to Electronics Point
It's hard to say - we don't know what type of camera you have. Can you post a brand and model number?
NTSC is a video standard for "composite video" that includes luminance (brightness) and chrominance (colour) on a single signal. In consumer equipment it is normally fed through RCA phono connectors.
Does your camera have a single-signal NTSC composite video output? If so, you can probably connect that to an RCA phono socket without any other circuitry.
If the video camera has RGB output (three connectors), circuitry will be needed to convert it to a composite video signal.
If the video camera has a USB or FireWire connection, quite a lot of circuitry will be needed to transfer the digital data from the camera and convert it to analogue video.
If the camera has a BCN connector... it could be outputting an NTSC or PAL video stream... are you sure it's NTSC?The camera has a BNC connector. I tried connecting it to an RCA input on a video converter, but no output on VGA. The camera has no model number. It is from China. It has a 12v power connector and a BNC output. There is a sticker on the camera that says NTSC.
Thank you for that.Here is the eBay description:
HD 1000TVL CMOS IR CUT Color Cctv Surveillance Camera Waterproof Video W89-10
Good to hear!Working now!
The video converter had a power supply issue. Tried another and it worked.
Thanks for all the help, guys. Haven't dealt with video cameras in several years and
the BNC confused me.
