Not getting oscillation as per circuit given
I am trying to generate oscillation to calculate rise time,fall time using circuit given. What change I have done is replaced inveter with SN74LS14. But I am not getting output .Crystal used is FX135A-327 .Any idea why its not working .
Should I change Load capacitance from 22pf to 12.5 pf.Is IC SN74LS14 correct for this testing.
That circuit uses a 74LVC1GU04. Why do you think you can replace that with a 74LS14?
Those 2 chips have more differences than similarities.
- TTL vs CMOS
- 1 gate vs 6
- Schmitt trigger vs normal input
- buffered vs unbuffered
- significantly different input voltages and currents
- significantly different output voltage and drive characteristics.
My reccomendation is that you try something closer to what is suggested. You may be able to get away with a 74HC04 if you are careful with the other inputs
