Hy i just bought DC DC Converter Step Up Boost Module 3V To 5V 1A USB Charger For MP3 MP4 Phoneusb charger.
specs are
Module Properties: non-isolated step-up module (BOOST)
input voltage: 2.5-6V
Output voltage: 4-12 V(Adjustable, the default 5 v)
Output Current: the maximum 1000mA
Efficiency: Up to 92% (the higher the input voltage, the higher the efficiency)
Switching frequency: 1MHz
Output ripple: 20mV (MAX)
Operating Temperature: Industrial (-40°c to +85°c)
Voltage regulation: ± 2.5%
so my question is when i power some device with correct voltage but weigher amperage what would happen.
if i power this device with 5v 3a would it burn
specs are
