non-volatile analog switch?
Jenalee K.
To make a non-volatile software programmable DIP switch. Anyone? Like
those non-volatile digital potentiometers.
Thanks,
Jenalee K.
L
Luhan
Is this switch wired as a circuit element or is it just read by a
micro?
Luhan
Joel Kolstad
How many DIP switches do you need? You can cheat and use those digital pots
if you don't need too many:
http://www.maxim-ic.com/appnotes.cfm/appnote_number/238
If you're looking for something that functions as a switch for routing signals
around even when no power is available, there are some RF SPDT switches
that'll still pass a signal from one input to one output or the other with no
power applied -- they use something like a MOSFET and trap charge to keep the
channel around without power.
---Joel Kolstad
E
Eeyore
How about latching relays ?
Graham
Adrian Jansen
Thanks,
Jenalee K.
If its simply for setting options for a processor, the standard solution
is an eeprom.
If you want to actually use the paths through the switch as current
carriers to other devices, you need to implement that with a processor,
and still store the settings in the eeprom.
If there are still any parallel eproms around, you can just use one to
set the control lines of a cmos switch directly.
Regards,
Adrian Jansen adrianjansen at internode dot on dot net
Design Engineer J & K Micro Systems
Microcomputer solutions for industrial control
Note reply address is invalid, convert address above to machine form.
L
Luhan
is an eeprom.
Simplest solution. Microcontroller sets control lines on analog
switches, writes data to internal eeprom, goes to sleep. On powerup,
reads internal eeprom and sets control lines.
Luhan
Jenalee K.
micro?
Luhan
Circuit element. The idea is to not use a micro to have them set on
power on, but they must be (remotely) configurable at
installation/maintenance time by attaching a progammer. I do not want a
dedicated micro because that implicates software development and an
extra programming operation at production time. I do not want real DIP
switches because users tend to change their settings and today
everything has to be software configurable anyway.
Thanks,
Jenalee K.
Jenalee K.
Graham
Latching relays (price?) could work but I'd have to add circuitry to
read back the actual position.
Thanks,
Jenalee K.
Jenalee K.
---Joel Kolstad
Great info, Joel. I'd thought about using digital pots but their off
resistance would be too low (up to 200k). And their bandwidth is a bit
limited. This appnote is a better way.
Do you have any references for those RF SPDT switches?
Thanks,
Jenalee K.
