Hi All,
I'm repairing an amplifier and decided to replace some of the non-polar capacitors. Out of curiosity, I'm testing all the ones I pull out. When I test them in my meter, I can insert the legs either way into the tester and I get a valid reading.
The replacement caps I bought are the same capacity, same voltage, same radial can, everything. They are clearly marked "non-polar." However, when I test them prior to installing them in the circuit, the meter will only give a valid reading when the legs are inserted in a given direction. That is, it's *behaving* as if it's a polar cap.
Is this normal? What causes this? My hypothesis is because the cap is unused and therefore was shipped with some polarization. But I have no clue.
Any ideas?
Thanks,
Bud
Any ideas?
Thanks,
Bud
