tns1
I am looking for an inexpensive (<$15 ea in 100qty) method to detect the
presence of line AC in a single, large gauge wire and close a small
signal switch (fet, bipolar, or) when current is present. The following
criteria apply:
No measurement or linearity requirement - only sensing presence.
Min threshold is 200mA, max is 200A or more.
Non-contact only, and the wire cannot be disconnected for installation
(so no toroids).
Wire dia varies from 1/4" up to 1".
The only methods I have considered so far are two-piece CTs and Hall
sensors. The Hall sensors do not seem sensitive enough for the low end
without an (expensive?) flux concentrating split core. They also need
more power than I want to provide, but that's ok if the price is right.
Other methods (GMR, Rogowski?) are possible but seem to have higher costs.
I have built a small circuit using a clamp-on CT that operates off the
small secondary current. It meets all the criteria except the larger
wire dia., so I know what I am asking for is reasonable. I really want
to buy a module like this if they are available, but all I see are
expensive measurement solutions.
Does anyone sell this type of thing, or know of a superior method? A
souce for low accuracy, inexpensive clamp-on CTs would be good too.
thanks
criteria apply:
(so no toroids).
thanks
