Hi
I'm controlling a 12v RGB LED strip from an Arduino Mega following the tutorial here >> https://learn.adafruit.com/rgb-led-strips/usage
I'm controlling with 3 pots via the Mega's ADC & everything works fine or so I thought!
In addition I have 3 servo motors that are also controlled by another 3 pots these also worked well when tested without the LED driver attached. As soon as I wire up the LED driver there is a crazy amount of noise generated that feeds back into the servo control that manifests as random jittering of the servos.
I have tried putting a number of different capacitors (basically whatever I could find in the cupboard) across the 12v - ground rails. Which do seem to filter out the higher harmonics of the noise but to get the noise (and the servo jitter) to disappear I lose servo response to their control pots.
Any tips on how to go about resolving this besides having 2 seperate systems running?
Are there any decent off the shelf drivers that dont create loads of noise?
