Hello,
I'm working on an audio/video switching circuit for old video game systems that use RCA jacks for left and right audio.
I've noticed a great deal of humming/buzzing in the audio which I would like to eliminate if possible.
I put 0.1 uF capacitors connecting the positive and negative lines for the output jacks and that seemed to clear it up a fair bit. I've also got 0.1 uF and 10 uF filtering caps on the switching ICs.
Is there anything else I can do to eliminate the remaining hum? I tried 0.01 and 1 uF caps too but they didnt really work right. The 0.01 uF caps seemed to do almost nothing and the 1 uF caps seemed to remove the higher pitch sounds leaving mostly bass. I dont have any other capacitors on hand but I could order some more in the 0.1 to 0.5 uF range and try those out maybe?
Is there anything else I can do besides caps on the outputs?
