Spehro Pefhany
Any idea what noise I'd see in a tantalum 150uF cap with 1.25V across
it?
Best regards,
Spehro Pefhany
it?
Best regards,
Spehro Pefhany
Spehro said:Any idea what noise I'd see in a tantalum 150uF cap with 1.25V across
it?
it?
Phil Allison said:"Spehro Pefhany"
** This a trick question ??
Like how many ohms in a coulomb ?
Celine Dion?Any idea what noise I'd see in a tantalum 150uF cap with 1.25V across
it?
it?
Best regards,
Spehro Pefhany
I'd guess just the thermal noise of the esr, which is only a couple
tenths of an ohm maybe.
John
it?
No sub-10Hz voltage noise as aluminum electrolytics under bias are
supposed to have?
I'm looking at a design (not my own) where there's an RC on the output
of a voltage reference feeding a Sigma-Delta 24-bit ADC. The R is
causing a full scale gain error of, oh, 17bits. 8-( Over 1%.
Is the reference input current constant with input voltage?
Temperature? I doubt it. 8-(
Spehro said:No sub-10Hz voltage noise as aluminum electrolytics under bias are
supposed to have?
supposed to have?
There most certainly is and it has been characterized as 1/f^2 down to
the millihertz region. From what I gather from the research papers
available on the web, most of this noise is due to thermal instability
around dielectric microleakage areas which self-heal via a chemical
transformation of MnO2->Mn2O3. These are characterized by a gradual
buildup of noise to a peak and then a substantial drop once the healing
has occurred. Also the very construction of the things makes them a
hotbed of tunneling and current trapping mechanisms as well as
possessing a nearly shot noise effect due to a
metal-insulator-semiconductor conduction mechanism from anode to
cathode. And all of these things are not even close to stationary,
varying all the time with a very slow trend into deterioration with
aging. This is all transparent to the majority of applications requiring
bulk capacitance at low ESR in small packages, but entirely visible as a
reference for a 24-bit A/D conversion application.
supposed to have?
Tom said:I've used tantalums at a point in a noise-filtering circuit where I'd
for sure have noticed noise much above 10 nanovolts/rtHz, and not seen
any. If you'd like, I could make a measurement with an AD797
amplifier connected to a couple biased-up caps, driving an HP89410
analyzer, and get a noise spectral density plot. I'm curious enough
about it now I may just do that anyway...
Tom Bruhns said:I've used tantalums at a point in a noise-filtering circuit where I'd
John said:FWIW I would love to see this. I have been using e.g. 2k2 feeding a
22uF tant as a reference noise filter. (Feeding a high impedance opamp
input). As I mentioned chip ceramics are a disaster here because of
microphony and perhaps temperature fluctuations.
Joerg said:[...]
Can't say that. I use ceramics all the time, never had such issues in
a Ref distribution and some of that is rather sensitive.
John said:Joerg said:[...]
Can't say that. I use ceramics all the time, never had such issues inI've used tantalums at a point in a noise-filtering circuit where I'd
IIRC I measured about a mV disturbance across the cap, when tapping
the PCB. This was when using some 0805 1uF X7R. I had to go through
the circuit and replace them with tantalums, in the critical areas,
which fixed the problem.
ref-[R]-.----- opamp> --.
[C] LED ----> Photodiode -> AC amplfier -> output
Basically I was looking for a small fluctuation on a large background
signal.
Hook up a 1M resistor and a 10u chip ceramic, with wires, to a voltage
source. Put a scope on AC across the cap. If you move the wires you
strain the body of the cap - this results in a visible output voltage
change.
I assume the same thing is going on when the PCB is flexed.
