Noise Cancellation in Old BiPlane
Joe G \(Home\)
Hi All,
I'm helping research for a system that can cancel out cockpit noise in a
professional aircraft headset (David Clarke). Hence noise cancelling
microphone are already in use.
The Biplane cockpit is so noisy that system is needed.
Do you know / recommend / Suggest a system that might be suitable.
Thanks in advance.
Joe
Spehro Pefhany
Hi All,
Thanks in advance.
Joe
What's wrong with buying a Bose aviation headset? About $1K US.
Eg.
http://www.bose.com/controller?url=...viation_headsets/aviation_headset_x/index.jsp
Best regards,
Spehro Pefhany
Joe G \(Home\)
Eg.
Best regards,
Spehro Pefhany
"it's the network..." "The Journey is the reward"
[email protected] Info for manufacturers:
http://www.trexon.com
Embedded software/hardware/analog Info for designers:
http://www.speff.com
Not bad -- but this cancels the noise in to the headset speaker.
I am also looking for cancelation of the noise getting in to the headset
microphone.
Regards
joe
G
Geo
microphone.
That is how the noise cancelling microphone works - it is open on both sides of
the diaphragm so that ambient noise (almost) cancels.
Rich Grise
[ top-post repaired ]
You are asking for a solution to the holy grail of aircraft headset
design. We've been after something to cancel microphone wind and engine
noise for the last 50 years that I've been in the business. The closest
we have come is a WWII design called a "throat mike". Look into it.
When I was in the USAF (1968-1976) they had headsets that were like
standard ear defenders, but with another piece that went over your mouth
and nose. It had the same kind of noise insulation (basically, a hard
plastic exterior and a bunch of soft foam inside) as the earthings, but
I think you still kind of had to shout into it, and it was uncomfortable
as hell.
But they _DID_ get the job done. ;-)
Cheers!
Rich
E
Eeyore
microphone.
Physically impossible.
Suggest you get a spam can instead.
Graham
Joerg
RST said:
You are asking for a solution to the holy grail of aircraft headset design.
We've been after something to cancel microphone wind and engine noise for
the last 50 years that I've been in the business. The closest we have come
Isn't it considered a sin in aviation to muffle that sweet sound of the
big old radial engine up front? I enjoyed every second of it, including
the oil splatters on the shirt. The owner had to then fly it back to
Mariposa and I asked him whether the noise would go on his nerves during
long flights. "Are you kidding? This is like music!"
K
krw
Right. It gets on his nerves when it stops.
Joe G \(Home\)
Robert Baer said:
Would such a system be useable to reduce PC supply fan noise?
Analog Devices has an app note on how to use a DSP to cancel fan noise.
JG
Joe G \(Home\)
Jim
I loke the Throat mike idea.... what did it sould like? normal voice or much
different.
Regards
Joe
Joerg
RST said:
The problem isn't to muffle the engine noise to the pilot, but to the
passengers if (s)he has an intercom OR on the aircraft radio which is nearly
unintelligible with an open-cockpit aircraft.
In the Stearman we did not have any problems with either and the gear
was not the fancy Clarke stuff, looked like plain old military issue.
K
krw
different.
A little garbled but I don't think you could tell the difference. ;-)
Joe G \(Home\)
I found out more... the BiPlane Pilot already has system using a mobile
phone. with an audio patch circuit to a David Clark headset.
I will get the pilot to ring my land line (POTS PSTN) and record the
iPlane - while he is talking to me and without any talking..
I'll record it using Opensource (free) Audacy software on a PC.... then do
a audio spectrum plot to see if we can notch out the noise.
I aleady have a telephone interface circuit that plugs in tp the microphone
of the PC...
Joe
Joerg
iPod, iPhone, iPlane ? Finally Apple must have come out with something
really useful. Cool! I wan't one :)
Similar threads
Y
Replies
2
Views
799
Rich Grise
H
Replies
5
Views
1K
Phil Hobbs
Replies
11
Views
2K
H. R. Bob Hofmann
H
