i have a old sony trinitron k21t3d tv. Problem is no vertical picture. when i turn on the tv 1 inch horizontal line appears.
Vertical deflection has two part one is tda8139 and other one is stv9379.
i checked the voltages tda8139 and voltages are good.
but ic501 stv9379(vertical deflection booster) have no voltage.
T802 is flyback transformer i measure voltage at 10th (24v ac) . No dc voltage. is it normal? because this voltage goes to ic501(stv9379 second leg) and not working.
Should i change stv9379?
Could you please help?
http://diagramas.diagramasde.com/televisores/KV-21M3A_T_M3B_T3B_M3D_M3E_T3E_M3K_T3K_M3L_T3L_T3R_M3U_T3U Ch.BE-4A.pdf
