No +5V for a switching mode power supply
A power supply (SMPS) outputs four dc voltages but one of them the +5 V have less than 2 V. The question is what component is responsible for the wrong output? What should I look for to fix the problem? Any recommendations ?
Voltage output : +5, +11, +19.8, +24
Current output : 0.15, 4.5, 0.5, 1.0A
Freq range : 50-60 Hz
Main components of the PCB
  • A1015 (LOW FREQUENCY AMPLIFIER)
  • C1815 (Audio Frequency Amplifier & High Frequency OSC)
  • HA17393 (Dual Comparator)
  • K2545 (DC−DC Converter)
  • FES8JT (Ultrafast Plastic Rectifier)
  • RS401L (BRIDGE RECTIFIER)
  • UC3842B-D (High Performance Current Mode Controllers)
Did you load the outputs prior to testing? Such PSUs usually require a minimum load in order for the regulation circuitry to kick in. Is there a separate regulator device for the 5V output? If so, it could just be a simple matter of replacement.
Yes, I load the output but one of them each time (not all simultaneously). I did see a seperate regulator 5V device.
