Hi all,
I'm trying to build this NiCd device to fix my batteries:
http://www.motherearthnews.com/diy/nicad-battery-reconditioning-machine-zmaz86mjzgoe.aspx
But I have a couple questions (b/c the diagram is hard to see):
What is the size of the TM (TradeMark) resister, 47K. 2000k, 5000K 0r what size is it 1/4 or 1 or 2 Watt resister. Need to know. If the resister is to small or to large the NiCd Battery Reconditioning Device will not work and could burnout the resister.
Also, looking at the diagram to build the NiCad fixing Device I can not determine the polarity for the capacitors in the wiring example. The instructions stress getting the polarity correct. Could someone please let me know the correct wiring polarity?
Also the K value for the TM Resistors is not provided. Do you have a guess at what this info is?
And what K value and wattage for the TM resister do I need? Could you provide a link for this resistor as was done for the 47 K resistor?
Thank you so much. Any advice you can provide would be very helpful. If you have any specific TM or 47 resistors you recommend that'd be helpful too.
-Joey
-Joey
