I'm trying to repair this pedal for a friend. There appeared to be
only one burnt out component and I replaced it but it still doesn't
work. It did look like something was spilled inside the pedal and I've
cleaned that out. When in bypass, the signal passing through is
distorted and garbled, like hearing it on a faint radio station. But
when the pedal is engaged, it doesn't pass signal at all. I'm pretty
certain that this is a copy of the Boss TR-2 because the schematic
seems to fit with the exception of the IC chips.
http://www.schematicheaven.com/effects/boss_tr2_tremolo.pdf
Since the "bypass/engage mode" is triggered by a momentary switch, and
the dry signal goes down a very processed chain of components, I
haven't been able to figure it out. What typically goes bad when there
are spills? From looking at this schematic, how would I go about
figuring out where in the "dry signal" chain things are wrong?
Thank you very much!
Olivia
Olivia
