I've got a very simple 12vdc circuit that I'm trying to add a delay of one of the switches signals to. Basically my circuit runs through a manual toggle switch for power on/off, through a small normally closed contact switch, powering a small electric motor. If the contact switch is tripped, the motor stops running, very simple.
I want to add a delay to the signal of the contact switch, essentially so that the switch has to be depressed for at least 1 second before it will cut off power going to the motor. The switch will get 30-40 contacts for a fraction of a second before it is tripped and held, I want to eliminate the rapid and sudden on, off, on, off signal to the motor.
I've been researching 555 timers, but I haven't done anything with 555s since school over a decade ago, so I'm having trouble even understanding the terms describing what the different modes and configurations are doing.
Thanks for any help folks!
