I have a simple circuit:
- 9v Battery
- 1 LED Light
- 1 Resistor at 1000 ohms
Question about Resistors
I'm aware that polarity doesn't matter with resistors, but does it matter if the resistor is placed after the LED if we're looking at the circuit from positive to negative. Probably a foolish question, but i have to ask.
Measuring Current with a Multi-Meter
When measuring current, the probes need to go in series with my circuit. Does it matter which probe I connect to the positive or negative side of my circuit?
This is my proposed way to check my current at the moment: https://postimg.cc/F7MD1mKb
The probes are disconnected by the way.
Also, when measuring current, does it matter where I start measuring? For example, if I measure current before (or after) the resistor, would it make a difference?
Measuring Voltage with a Multi-meter
When measuring how much voltage a component is drawing from a circuit, if it's an LED, can I just put the probes on the legs? Or is it recommended to place cables in parallel with the component?
Thanks!
- 9v Battery
- 1 LED Light
Thanks!
