Hello everyone,
I have a pair of Rokit Powered 6 RPG2 speaker monitors that I absolutely love, but on one of them, the woofer died and no longer makes a sound. I was planning on getting cheap replacements for $200, but most replacements are rear-ported which don't work well with my current set up. Instead, I took a look inside and I see all this burnt residue and one capacitor that is bulging.
I decided to buy a soldering station (X-Tronic 4010) for $40 and now I need to figure out a proper replacement for the bulging capacitor. The capacitor label says Yihcon 3300uF 50V and on the other side, it says RK 105(degree symbol)C(M) VENT.
I was looking at digikey.com but a lot of the capacitors there say things like tolerance, series, ESR, polarization, ripple current, etc., I am not sure which one to pick so that it works with my speaker monitor.
The capacitors are much cheaper than I thought, I was expecting to pay $20 for one, but it seems most of them are like $2-6, if you can recommend a premium brand that would be great.
Also, I don't have much experience in electronic repairs (I have only bought replacement parts and swap them in), the last time I did anything crazy was using a cheap eBay soldering stick to solder two 18 gauge wires together. If you can reference any great quick-start guides, I would also appreciate it.
Thanks!
Thanks!
