Hi Folks,
I'm Albe, a noob to the forum and sort of new to the world of electronics. I'm familiar with the basics of the basic components, wiring, schematics and soldering. I've done work in the electrical field and overall a jack of all trades; master of some.
I'm having some trouble figuring out a design to control a power window conversion I want to do to my car. For what it's worth, I've done power window conversions before on older American style vehicles that use the switch to change high current and polarity, no relays what-so-ever.
That being said, the car I'm converting is a '98 Volkswagen Jetta. Sure, the "easy" solution would be to find a junk vehicle and just swap the parts over but aside from finding a parts car with all the parts in working order, I've been told the VW power windows are a nightmare and have a tendency to be troublesome. This conversion utilizes a universal motor that adapts to the spline of my manual window regulators. These kits do come with their own switches but I have and want to utilize factory VW switches.
The problem is this; the switches control low current, possibly digitally, that in turn signals a central control unit that then determines which way to power the window motor. The switches have two common inputs and one output. What it looks like to me is that there would be a positive common, a negative common and when the switch was depressed in one direction the central unit would receive either a negative or positive power flow.
Going off this same theory, I drew up a schematic using standard bosch style 30 amp relays to control high current and polarity reversal needed to make the window motor go up or down, the only problem I have is getting one relay to fire in
one direction and the other to fire in the other direction. By using two relays with one trigger wire is posing to be troublesome. The power keeps looping back through the relay coil and energizing the other relay.
Can anyone help? I was thinking this could somehow be done with transistors? or with the relays and added diodes but from what my novice brain came up with I'm certain it's not going to work.
Thanks so Much!
Thanks so Much!
