I am designing a pump timer with 4 separate settable trimpot timers;
I also want to be able to adjust the speed of the motor using a trimpot as well.
I finally made the build but am having problems getting the motor pump to run.
I purchased:
When I connect the power source directly to the pump it does work.
I have tried all possible combinations with the outputs to the pump from the relay.
Any thoughts and advice would be greatly appreciated.
Thanks in advance,
Cribey
- 1 timer On for X seconds
- 1 timer On for Y seconds
- 1 timer On for A seconds
- 1 timer On for B seconds
I purchased:
- 4 x thse timers: http://www.ebay.com.au/itm/25240061...49&var=551248032979&ssPageName=STRK:MEBIDX:IT
- 1 x this pump: http://www.gearbest.com/other-consumer-electronics/pp_399925.html
Thanks in advance,
Cribey
