I have a very simple question about voltage dividers.
Why bother with the 2nd resistor? Aren't you reducing the signal to the desired level with the first one? What's the point of creating the parallel circuit after the first resistor?
You need to drop the full voltage across the two resistors.
You pick off the voltage you want, between the two resistors, chosen for the voltage
you want (when read between the two resistors).
It will work with a single resistor if your load has a constant impedance -- your load then acts as the second resistor.
However, in many practical cases, the load is of relatively high impedance and may not be constant over a frequency range (it may be AC coupled). The voltage divider has a lower impedance than the load so that the load does not significantly affect its behaviour.
OK, so to clarify, any unexpected spikes in voltage will be absorbed by the second resistor. The load may receive up to, but not exceeding the expected voltage.
My remaining question: How does this matter for dc?
No, a resistive divider simply divides a signal by a fixed ratio.
If both resistors are equal, the voltage across the bottom resistor will be half of the voltage across the two resistors combined (ignoring the effect of any load).
It works essentially the same way as a volume control does (since a volume control is typically wired as a resistive divider with the position of the control determining the ratio of the two resistances.
For AC or DC a resistive divider does exactly the same thing.
