I bought a old slot machine that was pretty much gutted but I hope to make it semi working by connecting the arm to a switch which will trigger the solenoids to cause the wheels to start spinning.
My problem is there is a cam shaft (much like one in a car) that is run by a motor to one by one stop the reels from spinning. my problem is on the end of the cam there is a lobe which I will use with a switch to turn off the motor but I'm worried that the lobe will stop with the switch still depressed.
I don't know much about electronics but I was thinking if there is a switch that once pushed in would go from on to off to on again even thought the switch is still depressed that would solve my problem, or maybe if there is a time switch that once depressed it waits a small amount of time before it breaks the circuit.
Any ideas are greatly appreciated
