David Farber
I am servicing an HP dv2125nr notebook computer. The problem was that it
came up with a blue screen while booting and said,
"unmountable_boot_volume."
I took the drive out and mounted it in my desktop pc via the on board SATA
controller. I booted to my system and ran a chkdsk and an anti-virus scan on
the notebook drive. It found some problems and fixed them. I put the drive
back in the notebook and it started working again. So far so good.
I put the drive back in the desktop pc and made an image backup to my
internal IDE drive. Still, so far so good.
I bought a new Fujitsu hard drive off of ebay, received it, and mounted it
in my desktop pc thinking I could restore the image file from hard disk to
the new Fujitsu drive. However when I powered up the pc, the pc speaker
beeped once as it always does after posting, then it froze at the screen
where it displays the components attached to the IDE and SATA controllers.
After a few seconds, the screen went blank and the system rebooted again. It
stayed in this loop until I had to manually remove the power. I was unable
to get into the bios settings. If I remove the new drive, of course
everything is fine again.
I called Fujitsu and told them the story and they said it could be a
firmware problem where it was only designed to operate in certain systems.
That was news to me. I never heard of a new, empty hard drive being designed
to only operate in specific systems.
Have any of you encountered a problem like this before? I doubt the hard
drive is defective but on the other hand, I can't think of any other
reasonable explanation.
By the way, if I put the new drive in the notebook and try to boot with a
utility cd, the same thing happens. It freezes on the HP logo though it
doesn't constantly reboot.
Thanks for your reply.
