Hello All,
Ok I am old but stubborn, so am going to follow this issue through regardless, my question / problem is as follows :
What is the most simplistic way to design a circuit board that will supply current to a small pager motor at varied intervals & duration.
IE : Run pager for 1 sec on 1 sec off, 3 sec interval then repeat, then on for 5 sec off for 2 sec and then continue to repeat that entire cycle pattern.
The cycling pattern will never be altered so can you program a small mc then place that chip on a board with power / motor and will run as is ? This is worded so basic its embarrassing but I self taught myself everything about 3D printing and design in autocad & solidworks so I am persistant enough to learn.
Finished deign needs to be as small and simplistic as possible.
Any and all help greatly appreciated if anyone has the time to spend enlightening me.
Steve
Steve
