Hey guys, new here. I've got a bit of wiring knowledge, took a good amount of circuits classes in college. Never really did much with relays though, so I'm simply not sure what to do here. Here's the relay I'm using: http://www.infitec.com/series/pdf/ff712857da68e826c15ec1c2eea07687.pdf
If you scroll down to connection diagrams, the specific model relay I have is the third to the right: 8-PIN BIR-BMR-BRSR. For my application, the seller told me I could wire the output in an X fashion so that it will reverse the voltage back and forth as it switches at each time delay. On the basic level, I don't know how to wire this. It comes with an 8 pin socket. I'm unsure of whether or not I need to fully wire all 8 connections, or if that's done internally and I just need to connect outputs and the voltage regulator input? To clarify, I've got a 12V battery as a source input, and the output is going to a small electrical motor that will spin one way or the other (based on positive/negative voltage.. hence why I'm looking to be able to do the X output to reverse voltage).
Thanks guys, I'd really appreciate the help!
