My question is about the concept of negative voltage in general, although the context from which it arises is to do with vacuum tubes in a guitar amplifier, biasing tubes in particular. This page http://www.vacuumtubes.net/How_Vacuum_Tubes_Work.htm states that "Bias is a negative voltage applied to a power tube's control grid, to set the amount of idle current the tube draws". At this juncture my confusion has less to do with the concept of biasing and more to do with what the term "negative voltage" means. My first inclination is to think "how can a voltage be negative?" From my understanding, voltage (through current in a loaded circuit) is the notion of electrons moving in a circuit to do some sort of useful work, like lighting up a light bulb for example. So what could the term "negative voltage" be possibly describing? The "unability" to do some sort of useful work? That is obviously not what it means, but you can see where my confusion begins. Many moons ago I came across this terminology in the context of digital electronics, where a transistor might be said to be "on" at +5V and "off" at -5V. The explanation I remember for that type of scenario was that the -5 was in reference to some benchmark, lets say 20 V, so that -5V actually means 15V and +5V means 25V. I could be way off on this and if so I would love to be set straight. Anyway, to make a long story short, if someone could help me understand what it means when a "negative voltage" is applied to a power tube's control grid, I would be right chuffed. Thanks in advance.
PV
PV
