When it comes to electronics, I'm basically in the First grade so was wondering if someone could help me with this. I'm installing an LCD screen in a car instrument cluster and the quality of the display on the screen doesn't look right. The contrast is off. The manufacturer of the replacement screen says contrast can be adjusted by changing the voltages coming out of 5 capacitors on the circuit board behind the screen.
The voltages should be (Manufacture Specifications)
V1 3.6v
V2 2.2v
V3 -4.5v
V4 -5.8v
V5 -7.2v
I measured the voltages and this is what I go
V1 3.5v
V2 1.95v
V3 -4.83
V4 -6.32v
V5 -7.69v
I'd like to add resistors to v2, v3, v4 and v5 to bring them closer to the the "spec" voltages but not sure which value of resistors to add in order to bring the voltages more in line. V1 seems to be OK but the others are probably the ones giving me problems. Anybody know the resistor values needed or an elementary way for me to figure them out ??
Thanks in advance
V1 3.6v
V2 2.2v
V3 -4.5v
V4 -5.8v
V5 -7.2v
V1 3.5v
V2 1.95v
V3 -4.83
V4 -6.32v
V5 -7.69v
Thanks in advance
