asdf
I am an absolute beginner so I apologize if my question is trivial or if I
use some wrong term or am verbose , but I would greatly appreciate help.
I have built in a delay circuit to my in-car cabin light so it will stay
switched on for 15 seconds after all my car doors are closed.
Now I would like to add to it an automatic activation of the cabin light
after the ignition key is set to the off position. My delay circuit needs
just one short ground impulse and it will be on for 15 seconds.
My cabin light is activated by the door switch that keeps wire at +12v while
a door is closed, and changes to a ground (0v) when the door is open.
I would need a simple way of creating a short ground connection on that wire
at the moment when my ignition is turned off (ignition on/off and the ground
wires are not a problem). Such a ground connection after the ignition off
should last less than e.g. 1 second and can be as short as practically
momentarily. When the ignition is on, this circuit should leave my wire
going from the door switch to the lamp undisturbed.
Could somebody, please, advise?
Regards,
Dave
Regards,
Dave
