I know nothing about electronics. Thought i should start there. But I have a Idea and willing to learn if the part i need exists or can be made.
So I want to make a box. A small cube, hoping for 33 mm but if it's impossible in such a small space then i can increase a bit.
This box will be a tiny power source. A toy kind of. I'm thinking a hearing aid battery like a CR927 3V. Now this will be contained within the box. At the top of this small box will need a small switch/button that turns it on and off.
The part I need to know if it could exist is some sort of power connector that's both male and female. This toy piece would be something like a LEGO that you connect other cubes to, hopefully by magnets at each corner, though the magnets might not be a good idea with a battery?.
So imagine, a cube with six sides, the bottom side will house a battery that can be removed and replaced with the bottom of the cube opening.
The top side would have a switch that has a external switch that presses down to turn the cube on and off.
Then the remainder four sides have connectors that connect to other blocks. Which would power them, each other block only serving as extension block and a internal LED at the top to make it glow. The connection should be any side of those to any 4 sides of the power source. Then the extension should be able to connect to other extensions on any side as well.
Does that exist? If so what is it called? Can i get one small enough to fit between 4 or 6[special extension cube] in a tiny cube? If it doesn't exist pre-made can it be made? How? And with what?
The power source doesn't matter much I could use two batteries or maybe a external power source for that block.
The size can also be increased but I wouldn't want by that much.
The purpose of the cube is purely decorative yet functional but not for much as the purpose is intended.
