Hey guys, ran into this site trying find an answer to my question, hope I can explain it well enough without knowing the proper terms... I currently have a 15 watt 12v solar panel plugged into a solar charge controller. The controller is plugged int a 12v 720 cca dual purpose battery. This is all working properly.
I am trying to run a small solar fountain pump for my wife. It works great in the day on its own but would like to run off my 12 v battery at night along with some l.e.d lights. I plan to use a photocell to have the battery supply power once its dark.
Now I know I can't hook up the pump straight to the battery, but my main question is what could I use or what size resistor should I get that would lower wattage or voltage to run pump safely. The pump apparently is 7 volt and the small solar panel generates about 1.6 watts.
Again I hope I supplied the useful enough information. And thanks you guys for your time.
