I need some help building a timer circuit. I've tried to design one using at least three 555 timers, but I just can't get my head wrapped around what the circuit needs to do.
Here are the functional requirements:
I have a NO SPST switch (+12VDC closed, 0V open) acting as the input. As soon as the switch closes, I need the timer to start. Timer needs to be approximately 3 minutes, but length of time is not critical. After the three minutes is up, I need the circuit to momentarily open an electrical equivalent of a NC momentary switch (10 seconds or so). The circuit should not reset with any further input from the NO switch, and the countdown should not alter once it has started, other than an input from a reset switch. This reset switch should be able to cancel the countdown without opening the (electrical replacement of the) NC momentary switch. Would it be possible to make this 'reset' switch a reed switch?
I tried to have a 555 timer do this, with two 555 timers (one on either side) to invert the input and output (as a 555 needs a low pulse for a trigger, and I have a high pulse of +12VDC). I tried to invert the output because I figured you would need to hold the base of (an NPN) transistor high to make it normally closed, and then lower the base voltage to 'open' the transistor. (If I understand transistors correctly, you could use a PNP transistor without inverting the input, because PNP transistors need the base low to complete the circuit, and high to open? Is that right?)
So far, I think this is my best bet, but I'm not sure how to translate it into what I need:
https://www.electronicspoint.com/555-used-delayed-pulse-generator-t7899.html
and
http://www.terrypin.dial.pipex.com/Images/10sMono+Pulse.gif
If there are any other options out there that are better, please don't hesitate to mention them. However, I think I may stick with analog circuitry, if it's possible to do so. I don't have any experience with microcontrollers, but I'm sure one would work fine in this scenario.
Any and all help is much appreciated.
Thank you very much for your time.
and
