Need service manual APPLE MACINTOSH COLOR DISPLAY M1212
I
Inty XP
Need schematics for thi Apple monitor (1994)
ahem.. the powersupply makes a buzz only,
Nelson
thereare only disassembly and regolation manals
i want hte schematics
I have never seen them. Apple's repair strategy is board level
replacement, so I'd be surprised if any are available unless they have
been reverse engineered. Let us know if you find any, however. I have
a couple sitting around that need to be repaired.
Also, I think they were OEM'd from Sony, although I don't know if
Sony's strategy is any different or if you could find the equivalent
model.
I
Inty XP
model.
The board is manufactured by Apple Computre Singapore, with a Apple part
number ecc ecc
but i reverse engineeed the secondary power supply, ancd the eht part.
the primary psu, based on TDA4605-2 is same as described in application
datasheet.
I
Inty XP
In data Sat, 24 Jun 2006 20:57:19 +0200, Inty XP <[email protected]> ha
scritto:
I reverse enginereed almost of the P.C.B (excluding VERTICAL, EW,
uprocessor, RGB)
James Sweet
Apple has never released schematics of any of their stuff, at least one
company out there has reverse engineered much of it but aside from that
you're on your own.
I
Inty XP
In data Sun, 25 Jun 2006 00:26:41 +0200, James Sweet
you're on your own.
But there are schematics of Apple I, Apple II, Mac SE\30, Plus, 128k & 512k
logic&analogic boards.
But : printers, PowerMac, ecc are secrets :p
Many thanks, i reversenginereed it yesterday night :p
