Need pinout for a Kantech CBLK
I would like to connect a Kantech KT300 to a Lantronix UDS1100 server device. Would anyone have the pinout from the KT300 6 pair flat cable to the 25 pin DIN connector?
Did you Google? The first hit is a complete installation PDF that describes the board if full detail... I'm guessing the pin out you want is the RS232 cable to the DB-25 parallel port? If so Google that, I highly doubt they deviated from the standard RS232 to DB-25 parallel port pin out, and a little continuity check will set you straight and verify that...
